SS-V: 5020 Lateral Buckling of a Right Angle Frame
Test No. VNL03 Perform analysis of buckling and post-buckling of a thin-walled frame-like structure in the shape of right angle.
Definition
Perform analysis of buckling and post-buckling of a thin-walled frame-like structure in the shape of right angle (Figure 1). One end of the structure is clamped, and a conservative load in X-directions is applied to the other end.
- Properties
 - Value
 - Modulus of Elasticity
 - 7.124e+10 pa
 - Poisson's Ratio
 - 0.31
Figure 1. Geometry and loading
Results
Structure is simulated as a solid. Reference critical load found from 1D beam bending model of the structure is P = 0.820035 N. Negligible perturbation load of Pz = P*1.e-4 = 8.2e-5 N is applied in lateral Z-direction at the loaded end of the structure in order to cause a very small initial deflection of the structure from the flat. The main load was gradually increased from 0 to 1.6*P.
Figure 2 shows maximum deflections versus applied load. The load-lateral deflection curve is in a good agreement with the results reported in the reference. Transversal post-buckling behavior at first is associated with a very small transversal stiffness, but then the load carrying capacity increases (load-displacement curve flattens). In-plane behavior is almost monotonic, no capacity increase occurs in the range of load change.
Figure 2. Load deflection graph
Figure 3. Deformed shape and von Mises stress plot at load 1.4 N
